Side Mirror Lights
So I'll start off with: Please don't laugh too hard at the below picture; I am not looking to do this to my truck!
Just curious if anyone has done (or seen) anyone add LED lights to the front of their side mirrors, like in the picture?
http://www.rigidindustries.com/led-lighting/20611was an example of something I was thinking might work. Anyways, anyone done this? Not sure how much room is behind the mirror of if this is impossible to do? Would kind of look like the FJ Cruiser but much better.
Thanks.
Love the picture. Lol. What would be the purpose of the light? Park/Running lamp like OEM method?
I'm not 100% sure yet, but probably as an aux light with a separate switch in the cab. They'd basically be like spot lights, but those are typically adjustable; this would just be forward pointing.
Gotcha. I haven't taken apart a Towing mirror but based on some videos I've seen of those making the dual park lamp / turn Signal modification, it looks like there is room.
i think it'll look tacky on regular mirrors since they are curved on the back. would look better on a flat back mirror like the tow ones.
I posted above you a link to an angled mount that would help correct that issue, but I hear what you're saying.
what about doing the mounts up near the window cowl under the hood?
Thought about that but I don't love the look of the mounts for that.
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 592 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
