Canned 4.8 or Tuned 5.3
Emg.27
I have a 2002 Silverado 1500 2WD.
It has the 4.8L vortec with 225K Miles ! Its still alive ! Lol
It runs good. Only things is when you're at a stop and floor it. It kinda chokes... and stalls and lags . Then its goes haha. Not too bad. But noticeable . Anyways. Should I swap it for a 5.3 Tuned or keep the 4.8 rebuild with performance kit & cam ?
Cammed* excuse the typo.
The 4.8 and 5.3 are identical engines, only difference is the 4.8 has a shorter stroke and hits its power band higher in the rpms. You have a genIII LS engine which means it doesn't have floating pins and the piston rods are not as strong as the newer gen4 engines from 2003 to 2007ish.
Depending on budget, I would find a used parts place and get a 6.0 or 5.3 with around 100-150,000 miles and build it from there. If you switch to a gen4 engine you have to get or make a harness to extend knock sensors and get a cam relector wheel that works with your computer, and a tune is needed no matter the application.(use blackbear, don't waste time with Diablo or superchips preprogrammed stuff)
GenIII engines are generally safe to about 500wheel horsepower, so 600ish brake horsepower with stock bottom end. Also when you increase hp the stock trans will need to be built, a stock 4l80e swap is a safe and cheap bet with a converter stall change depending on hp. But the 4l60e trans will not survive long with increased hp. So that needs to be considered as well.
Gen4 can handle around 700 wheel horse power with stock bottom end.
Also it's a good time to take the rear diff cover off and check for metal and end play.
If you just want the "cam sound", throw a cam in your 4.8 with high lift. The 4.8 also has flat top pistons which increase the compression ratio and limit the lift the cam can have. Look into what heads you have as well. If it's 243 head they have small intake valves which limit the amount of fuel you can dump into cylinder, so those will need to be upgraded/rebuilt/replaced as well.
Also if e85 is available, I'd do a conversion for free hp with a tune, just need a diff fuel pump like a walbro 400. The injectors will also need to be replaced with higher psi ones, stock injectors are smaller on the early 2000 trucks, yours may have the bigger stock ones but idk for sure.
Exhaust and headers: don't waste time with shorty headers, go with longtube headers, catalytic converters do affect hp but I usually just leave them on or replace with high flow cats, true duals don't make much of a difference that it's noticeable, I hate flowmaster fart cans cause they rust out in couple years(live in salt belt). If emissions are not an issue just straight pipe it. Doesn't drone on highway until it shifts into 3rd to pass someone.
I personally have a 1999 4.8l sierra as well and find it has plenty of stock power that can be coaxed into it. I have 3.73 gears and have no problems squeeling the tires running stock.
Cold air intake is not really much of an upgrade, let's water into intake and more dust, plus you have to clean it more often, otherwise it actually hurts performance if not maintenanced properly
Don't hold me to everything I just posted, things I said may not be 100% correct as I just wrote this off the top of my head from own experience and past research.
Sent from my XT1254 using Tapatalk
    • Part is $233.87.     Not sure where $900 came from?
    • Looks like you have it figured out. Did you run a sensor into the rear diff housing?    What sort of diff temp swings would you see towing or not? I have wondered how hot it can get
    • Dealer just confirmed that GM is "out of AC compressors."  Not sure if all 2019 to 2026 trucks use the same compressor, but a shortage like that is hard to believe.
    • I think we're reaching the end of constant projects/work.   The water pump bolt appears to have self-sealed, as it's not leaking anymore. I'll take it, and, I'm ready should it self-unseal! I was also getting an oil leak at the front oil pan seal and timing cover and came to find a pan bolt on the corner wasn't even finger-tight. Too easy. And, it was. But, it appears tightening it has reduced a leak producing spots on the ground every time I parked, to just a weep, leaving an occasional dot on the cardboard that lives under it while parked. That's acceptable on a 30 year old engine in my book. I do hate leaks, but, replacing the pan seal is quite the job.   The rear washer line is reconnected and the sprayer works, although getting an intermittent washer fluid drip off the bottom. I think it's just residual...the reservoir filled up the channel in the rear floor and drained down into the upside-down spare tire/wheel. So there are residual puddles all over under there, will wait a few days for it to spill out and dry before I go chasing a potential leak.   The door speaker...no dice. Speaker works just fine, it's that channel in the factory amp that's gone bad. Can't win 'em all. And, whomever buys this will probably tear out the factory radio for something more modern anyway.   I put about 110 miles on it yesterday. Put a lot of wind and heat into it with some mountain driving. Still runs great. Near the top of the pass I got off on a gravel side road and put about 10 miles on with 4hi engaged. Works great.   If ya squint, she's mint! God I wish these were still in production. I can see why they're not. They're rudimentary bordering on agricultural. They began life as a pickup truck and then modern society demanded the rear be enclosed for kids and crap. They're still a pickup underneath, and that gives them lots of ride character, sway and bounce and bump steer. They're alive on the road, and, at least for purposes of nostalgia, it makes driving one a lot of fun.   The Check Engine light did come back on the pass, P0134 for the upstream O2 sensor dropping out. Putting heat into the exhaust causes it after about 10-15 seconds of increased load at higher RPM. The downstream sensor is completely mangled (someone clearly had a rough time removing it, but they didn't replace it?) so I'll just put two in it. For what, mostly to cure the CEL, I can tell the cat is damaged. It's not plugged or fractured, but it's not catalyzing. There's some guilt in not fixing it, but at a cost of $500+, the truck just won't get driven much under my watch. I dislike the smell...running the truck in the shop even with both doors open and the overhead fans blasting, I still reek of pre-cat exhaust. Sticks to clothing and everything else.   Window motor (I'm dreading this), and tires, and that should be about it. 50/50 on Starfire Solarus H/T's, or spending $20 more per tire and going with Cooper Discoverer RT's. I like the look of the RT's a lot more, but is it worth it? I've got a really good (just very old) Toyo Open Country XTX on there now and I like it.
    • From what I've seen, they "could" sell the switch but designed the assembly such that the switch can't be readily removed and replaced without removing a plastic locating pin.  Sure appears aimed at forcing the end user to purchase a $900 shifter assembly instead of a $20 switch.  Thankfully I still have some extended warranty left...  this one has had warranty repairs almost every 5K miles from the day I bought it.
