Motofab 2.5" top spacer or TGC 2.5" ?? Advice needed
I suppose you're right. Though I want 2.5" so the reason I'm torn is, my height difference is 2.5" currently. So I dunno if I want to just get the 2.5" top spacer....or the 2" lower spacer and 1/2 upper strut spacer.
I'm not sure if all kits are like this. But, a 2" kit may not physically raise it 2" because of the suspension geometry. It will be very close, just not exact. Seems like they sell the kit size according to the actual thickness of the spacer. Some kits may not do that and they figure out the actual lift size, but I think most if not all go by the spacer thickness.
Personally, since I like using a truck as a truck, I actually like and want a rake. I wouldn't want ti exactly level because any kind of real weight you put in the bed or tow it will make the truck look like it's dragging ass.
Now the more I read up on motofab, especially via Amazon, they have what seems to be the worst customer service of any lift company.
Get on eBay and buy a 2.5" bottom spacer. The ratio is about 2:1 which essentially means a 1.25" spacer will give you 2.5" of lift. A metal spacer is a metal spacer no matter who makes it. I've put hundreds of these on and can't tell a difference besides the label.
I bought one from summit performance on ebay. I bought from them because they have a good seller rating and the ONLY company I've ever seen make mention of machining their blocks to coincide with the angle that exists on the lower strut mount.
    ottogriffin
    ottogriffin
  • Who's Online   2 Members, 0 Anonymous, 596 Guests (See full list)
