bad news??
Hey guys, need some help, I went to start up the truck tonight and heard a god awful noise(see video). This was accompanied by what I would say is an oil fume smell in the air. No oil on the ground or around the engine that i can see, checked levels, all good there. Any thoughts??
  • Replies 31
First off, don't try to crank it again. She's sick.
Rod and/or rod cap. Bad stuff dude.
I appreciate the response, I will have it towed to the dealership in the morning. I am by no means a mechanic, what would cause something like that? Now I am trying to remember if drivetrain is under warranty for 100k miles....
Power train coverage is up to 5 years/100,000 for 2015 or less. 5 years/60,000 for 2016 and up
Makes me glad I didn't put a tune on it...I'll update once i get the final word from the Dealership
That sucks. Sorry bud. On the bright side of you get a new engine out of it under warranty it might be a blessing in disguise. Just trying to think positive.
Sent from my SM-G930V using Tapatalk
Oh I totally agree, I'm at 90k miles right now, so its good timing?
exactly. good thing its a '15 so its got the 5 year/100k
Sounds like something is rubbing / loose / wearing out to me.
Sierra Boy
With my bad hearing and listening to the video, I'm not sure it isn't something fairly simple. Maybe a spark plug blew out or a lifter/valve stuck. It doesn't sound like a rod or main bearing to me.
interesting, the thing that really worried me were the fumes it was giving off, once i smelled that I shut her down immediately
Any check engine light or other warnings present?
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 431 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
