So what do yall' think about the Lakers?
bowtie_pasta
I think I MIGHT actually watch an NBA game this year to see how they do. I haven't watched a full game since the Detriot Bad Boys broke up and MJ, Worthy, Scott, and Kareem pleyed in L.A.
I watched a LITTLE to how MJ was doing and I watch a LITTLE once in a while to see how Kobe does.
Like I said I MIGHT watch a game, unless there's something else on I'd rather see.
Honestly,I'm never watching another NBA game again after the signings are official.
The league can't stand it when a small market team gets more than 1 or 2 good players because they feel that they will lose money from smaller market and this business of the Lakers getting away with signing these 2 because of exemptions is ridiculous.
If they keep 3 of those 4 players healthy for even half of this coming season it will be the most non competitive one on record and outright boring IMO.
They'll still have one team that will be competitive, the SPurs. When they get Kidd and Mourning they'll compete with them. I have a feeling that the chemistry there will come alot easier than Kobe, Shaq, Malone, and Payton.
Basketball sucks and the league is struggling for fresh ideas. When they let Iverson continue to play after trying to strangle his coach during a game, that's when the game lost total credability with me. That jerk should have been banned from the game for life.
That was Spreewell who choked his coach and the Nets,not the Spurs,are going to sign Mourning as well as retain Kidd.
Oops, my bad. Spreewell was the guilty party. I'm sure if you walked up to your boss and tried to strangle him (like we all want to), you'd be spending a little time in the cooler.
Elwood, that would have been very true, but look at this, looks like he will be staying in NJ. Kidd to Stay in NJ
Just going with the last report I heard on Sportscenter. I don't follow it real close, just what I see on there. At that time they said the Spurs were the front runners, then NJ, then Dallas. But it doesn't suprise me, because from what I heard Kidd really likes NJ, he just wants to play with Mourning.
It just sad to see that after so many years together, Malone and Stockton won't be winning the championship together though. :(
The lackers will perform down to their usual standards this year.
Shack wil show up to camp with his new overstuffed 400 LB body.
Moses Malone will severly pull his Groin 10 times and never play a minute.
Kobe serves his time and watches the season from the exercise yard.
Payton ...Walter is the only good one.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
