2017 Silverado Z71 on 22" rims and leveled. what are the biggest tires i can run without too much rubbing? Thanks
Edited by Kambeaux
If only there was a way this question could be searched and provided an answer in this forum? Hmm, oh there is and since this question is asked often there will be tons of results.
Also before asking a generic repetative question you might want to provide more info. Are you doing a 1 inch level a 3 inch level? What tires are you running a street tire or a mud terrain? Are you off roading or is this a street queen. Are these factory wheels or aftermarket?
You can fit a 35's with out too much rubbing, but again just search...
Tyler
solid answer amxguy. on a side note when I joined this site, I asked a question much like the one posted, and received almost the same response. I was new to the forum and hadn't a clue how to find the shit I wanted so I just asked. The negative feed back was almost enough to keep me from coming back.
“Tact is the ability to tell someone to go to hell in such a way that they look forward to the trip.”
― Winston Churchill
Lesson is: don't be a douche.
On a side note I currently have a Rough Country 1.75" (early kit) lift and level, and a 1.25" body lift on my 2014 sierra 1500. I just swapped out my 33X12.50R20 (Interco VorTrac) for some LT305X55R20 (General Graber X3). I added a .25" spacer when I changed tires, and neither tire rubbed much... a little, but only at full lock. but then again Im not running 22"
Edited by Weazelwacker
  • Like 3
  • 5 years later...
