Will 35s fit
I have a 2016 lt 2wd on the ugly 17s. I have a Titan on 35s toyo mt 17. I was wondering with a 2" level in the front can I simply have the tires swapped and fit the 35s?
No. With 2" you would be hard pressed to even fit 34's, and you would probably need to trim.
275 wide x 34" seems to be about the tallest I recall someone had success clearing with a 2" level. Wider than 275 would likely need to be shorter. I have 305 x 33" on a level and no rubbing. But it's close
