295/60R20 On 20x10 -19's
Running a 2.5" Motofab front spacer and a 3" rear block and I got a good deal on the tires and rims but I am just nervous I will rub like a SOB. I figure I will do the zip tie mod to bring back the carpet, but does anyone have experience with what I am trying to stuff under this pig.
I tried searching and didn't find the answer so please don't tell me to search the forums as I have done that and even looked on Custom Offset and couldn't find an answer.
I compared my setup to what you are wanting and going to rub pretty bad.
https://www.wheel-size.com/calc/?wheel1=33X12.5-20X9ET27&wheel2=295-60-20X10ET-19&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm
Your combined wheel and tire will stick out about 3 inches further than my setup.
I have slight rub at full lock and imagine it would be much worse with a setup that is 3 inches wider.
Hmmm. If your running a 12.5" wide tire and I want to run a 11.5" which is an 1" narrower but the rim is 1" wider. So is it the height or width that would make it rub?
The 295/60R20 Atturo Trail Blade X/T has a diameter of 34.2", a width of 11.5".
Width according to the wheel size calculator. Your prospective setup sits 84mm further out or a little over 3 inches than what I have. This is due to the negative offset of your wheels plus the 1 inch difference in width.
Well shit! Now I gotta find new tires!
Its not the tires causing the problem its the wheel/rim that is the issue. May want to consider a 20x9 wheel with a +12 or +18 offset. Tires you want should work.
Yeah problem is I kinda committed to some 20x10 Hostile Gauntlets which are -19's..... maybe I will toss them in the For Sale section and see if I can sell them....
Why not just trim? Everyone acts like it's such a huge deal, if you do it right and put the fender liner back most people would never know the difference.
Guys are running 20x12s -44 just leveled they just have to trim some metal. I'm sure you can get those x10s to fit if you really want to run them
Yeah just don't want to cut up a brand new truck.....
You don't have to cut much, most likely it be the pointless air dam. or you can choose to just bash the wheel well on the parts that make contact.
I personally would chalk the whole inside tire wall and make full turns well moving very slow to see the parts of the liner that hits.
You also have to remember that the tires specs never are what they say, most 33/12.50 after on a 9-10 inch wide rim often are only 32 inch tall
When it comes to tires its like putting up a door, you have to make sure it fits then can it open and close.
I see so many people running 35/12.50 on just level and blocks when people say you can't. you will be happy with the tires!
Yeah I'm still on the fence about this setup, cause I do go off-road to run bear baits and don't need to cut down a tire or mess something up. I was hoping a member had these same tires but I couldn't find anything really in a search with this offset o
Maybe I missed it but why can't you change the tire size you want? I'm pretty sure if you went a smaller tire size you could make those wheels work with that offset. Just an idea
I can go to a different size, just found a smoking deal on those size, $700 cash. Just need to go pick them up if I decide to do some trimming.....
