Help!! Codes p0449,p0455
Thank you I will check today and let you guys know what I found
Thank you for help me guys on this problem after make a test on the connection for the valve I found no power so I track the wire from conection to the fuse and I found the cable was BROKE so I fix the cable and the code is no longer coming up.
The problem is FIX
