DIY Home Made Bed Slide with Drawers
Newbie here! Thought I share my bed slide I built for my 2011 Silverado. It has twin 6' drawers and I have had over 1000 lbs on the bed slide. Check it out and let me know what you think.
that looks really nice. were you tempted to put latches that you could put a padlock thru instead of the catch latches?
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 699 Guests (See full list)
