The transmission seem to shift fine, no strange tranny issue that I can notice. Its still under warrenty so I may bring it in but knowing this dealers who knows if they will feel the same thing. They may just say some BS like "thats normal".
The transmission will shift normal if the TCC solenoid is getting stuck or if there's some type of trash in the valve body at the TCC solenoid. This solenoid doesn't have too much affect on upshifts. So this is why you wouldn't suspect a trans issue. There may also be a history code in the TCM they can work on. Tell us what the dealer finds out, if anything.....
Thanks, I'll have to make an appointment and see what they say. Should I even mention anything about a possible TCC issue?
You could hint at it at least. Or make your complaint say something like "it feels like manual trans going to stall without pushing the clutch" any trans guy should immediately start thinking TCC lockup
Justin has a lot of insight and experience and as in recent posts, is on the trail.
My thought is to put it in neutral vs in gear while coasting down. The TC shouldn't come into play in neuchie
Edited by spurshot
Well, I was out and tried this, in neutral it does not do it so, it looks like its a tranny issue. Now to get the dealer to pay attention to my issue and fix it.
Edited by slickman
Made a appointment for this friday so, lets see if I have a fight ahead of me.
Shouldn't be too hard for them, but you never know. Definitely TCC fault going if it's okay in neutral. You may also have some darkened clutches from it staying on as well. Request pictures from the disassembly. Post them here! WE WANT TO SEE!!! [emoji23][emoji23]
Oh and don't forget there could be something stuck in the valve body itself, stopping a valve from moving or maybe a valve bore that's not quite circular. Normally I take a pocket screwdriver and move the valve back and forth easily to see if it moves, it won't take much pressure. If it has to be forced, the valve body needs to come apart. If they are free, checking the TCC o-ring and fitment in the bore is a good idea. If it shudders every time you slow down, then it should be relatively easy to narrow down. If it's intermittent, I would go ahead with replacing the TCC solenoid after the valve body inspection.
Edited by Justin101714
Well, was at the dealer today and a service bulletin was done that they said is what would fix it. So far its MUCH better, it seems to be doing it a little now but I may be overly sensitive so I'm going to give it a week. But right now it seems fixed.
Edited by slickman
I've been having this same exact issue for the past week. Slowing down from from 30 MPH to a stop, may have to make an appointment too. Rotor's and brake's are fine.
  • 3 months later...
What exactly was the service bulletin they performed, I also have a vibration in steering wheel at low speeds.
I've seen a very similar issue on other vehicles when the pinion angle gets out of whack.  Have you done anything that would alter the pinion angle without readjusting it (lowering/lift shackles)?
I have a flip kit and hanger set at 5 in the back. I had a reputable shop in Okc install a two piece driveshaft which fixed the shake vibe at highway speeds and the jump seat doesn’t shake anymore, but the steering wheel vibe is still present at 20mph. It’s funny it doesn’t do it all the time, so I don’t think it’s driveline related. I’ve had the tires balanced several times at different shops, just had an alignment done that helped a little bit.
I am having a similar issue after installing 2.5" rear lift blocks and a set of Bilstein 5100 set to 1.85". Feels like bad shake while braking, felt through pedal and stearing wheel.  Starts at around 70kmh very slightly worsening as I get closer to 30Kmh.  I believe my problem is pinion angles do to the wrong style block??  (all installs were done by a shop and it did receive an alignment. Also has been back and everything checked over)
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,320 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
