Heated Seat Issues?
STINSAN3
10 hours ago, Loco-diablo said:
The heated steering wheel is one option I wish I had. My LT has Bose, leather, power rear window, blah, blah, blah...but no heated steering wheel. I could really use it this winter here in New England where we’ve been freezing our asses off. Bummer
You would think if had all those options it would have a heated steering wheel.
I love mine, I just wish it turned on when I start my truck via remote.
I have a 2014 LTZ.  The driver side seat heater does not work.  Is there a fix for this, or just live with it?  Is this something I can do or do I need to take it to the dealer?  It is not under warranty, sadly to say.
Well, most anything can be fixed, just depends on your individual skill level. You’ll have to troubleshoot the problem of why they don’t work & then make the necessary repairs. More than likely, the seat will have to be removed and at least partially disassembled.
If you’re comfortable with all that, then you can maybe do it yourself, otherwise you’ll have to take it to the dealer.
thank you for your answer.  I fully understand it depends on my skill level and all that.  I guess what i was trying to ask was...is this a known problem?  And if so, is there a recall for this?  If not, I will repair it myself.   Thanks in advance.
They are known for having crappy seat heaters; however, it’s not really nailed down to a single issue. For example, my 2014 is going in tomorrow because neither bottom seat heaters work but they don’t share the same problem.
There wouldn’t be a recall as it’s not a safety concern. I believe there is a TSB on it though.
This is why I always order ----- you don't spend the next several years telling people what you wish you had.
    B07
    B07
  • Who's Online   4 Members, 0 Anonymous, 877 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
