Carry-All enclosed trailer
Donstar
Our Lowe's sells Carry-All brand trailers. I am particularly interested in their 6' X 12" V nosed enclosed trailer. I have owned a couple of Interstate brand trailers in the past but had some poor quality and support issues with my last purchase. The trailer would be for light use such as hauling my motorcycle and other bulky items to warmer places this winter. Any "red-flags" ?
No experience with this brand. Brother in law had 2 new Haul Mark enclosed trailers, both had issues. From wiring to structural, nothing major. Another friend had a new enclosed trailer but I can't remember the brand. Used it to move to another state and other short hauls of furniture. After about 10k miles the rear doors wouldn't close properly. I believe it depends on if you get a good one off the assembly line, just like a vehicle.
I have more experience with boat trailers and believe it depends on assembly line luck, again. :happysad:
They're "ok". This is the same company that makes trailers for Tractor Supply. Lots of the open trailers on the road, and they hold up ok over time. I do see the enclosed ones out there, but not a lot. Have no idea how they hold up over time. Be prepared to rewire them as that is a common weak point. The lights are usually whatever commodity item they can get and don't always appear to have been part of the "design". You may also want to consider rewiring it immediately then taking it to some place that does truck bed spray-in liners and having them spray the underside to protect the axle from rusting.
Factor in how far / often you're going to drag it and compare the costs of towing it against spending more money on something lighter that you'll get better fuel economy with.
Good advice and I think this trailer may be too much of a compromise between a need and a want. I actually want a double axle enclosed trailer with brakes but do fine with my 4' X 6' open utility trailer! The V nose strikes me as being potentially easier on fuel to drag than the flat faced version.
If it's the "shallow" V-Nose (meaning it only protrudes about 12" in front of the sides), I can't imagine that will really make any significant change in the amount of drag is creates.
You can always put small things in a big trailer, but it's impossible to put big things in a small trailer. :)
  • 6 months later...
Carry-On cargo trailers are an entry level occasional use cargo trailer.
Interstate uses hat channel uprights vs z-channel in the walls.
The Interstate is a step up from Carry-On as far as construction.
  • 3 weeks later...
Completely agree with the last sentence!  A good rule of thumb, if you have the space to store it, is take the size you have in mind and add 4’. I was looking for a 7x12 tandem axle enclosed trailer to use mostly for our move up north, and for work once the move is done, but I came across a decent deal on a 7x16. Im glad I pulled the trigger on the bigger trailer, not much heavier when empty and the extra room has been a huge help.
Regarding a v-nose and fuel economy, the biggest *drag* on fuel economy while towing is the big flat spot at the back of the trailer causing turbulence and drag. That’s why some trucking companies have those folding flaps on the back of their trailers. I’m sure the v-nose helps but probably not enough to negate the drag at the back. I still like the v-nose for the extra space inside without adding a whole lot to the overall length.
    • New to this forum.  Also looking to tune a 6L80 and trying to work out all the issues in my transmission swap.  I have a 6.2 diesel (1983) and have removed the TH-400 and about to put in a 6L80 with a TCM-2600 interface and don't have a clue what I doing after that.  Did you (Leatherneck/RAV3) get your slip resolved? I too hate to spend that kind of money on a tuner that hopefully I will not need too many times although from what steelerdude15 added about the HP Tuner being great for diagnostics would be a plus.  I am also from WNC but below you in Columbus.  Any helo would be greatly appreciated.
    • Sounds like a smart reasonable person with common sense. Bill O’Riley never said he was just a journalist, by the way.
    • It's like saying Bill O'Reilly is "just" a journalist.         Lauren Fix, widely known as "The Car Coach," is a prominent automotive journalist, television personality, and self-identified conservative. She is a frequent contributor to right-leaning networks and platforms, offering commentary that intersects the automotive industry, consumer economics, and conservative political perspectives. [1, 2, 3] Media and Commentary Network Contributions: Fix serves as the National Automotive Correspondent for Newsmax and is a frequent guest on Fox News and Fox Business. Video Platforms: She has contributed to PragerU, where she has hosted videos critiquing government mandates on vehicles. [1, 2, 3] Core Positions Anti-EV Mandates & Fuel Policies: Fix regularly critiques government subsidies and mandates for electric vehicles (EVs), framing them as impractical and burdensome to the average consumer. She advocates for consumer choice and supports traditional internal combustion engine vehicles. [1, 2, 3] Economic Analysis: Her commentary often emphasizes the impacts of fuel prices, inflation, and federal regulations on drivers. [1, 2, 3] Political Alignment: On her public channels, she actively supports deregulation, "drill baby drill" energy policies, and the removal of government restrictions on auto sales and manufacturing. [1, 2] For analysis from Lauren Fix on how consumer automotive choices can align with political leanings:
    • Wouldn't swapping out the original AFM/DFM parts for a complete Delete Kit be the best route to go if one could afford to go that route?
    • It comes with directions but yes, generally, it's the same.  Also, get you the dipstick stuff to install dipstick so you have one.
