I bought a 2014 Sierra SLT certified used and am having a strange issue. Whenever I get close enough to an object parking and the warning goes off, I get a service driver assist message that I have to reset. Is there a problem or are you forced to manually reset this warning every time?
Check under the drivers seat for a small black wire that connects to both sides of the seat bottom foam. There are two haptic motors left and right on the bottom pad. The wire to one normally breaks. You should be able to pull on the wire pretty firmly and it shouldn't pull out, if it does, it's that haptic motor. Replace it. Done a whole lot of these for that particular problem.
I have a 2014 High Country that I bought new. I started getting the Service Driver Assist message a few weeks ago and my setting changed to audio, could not set it to the seat vibrator. Truck only has less than 24000 miles but over 36 months old so warranty is out. Dropped it off at dealer the other day for oil change and tire rotation and asked them if they knew what might be wrong. Said they would check it.
When they called that it was ready, said the left haptic motor was bad in the seat and it would be $399 to replace it!
Once I recovered I told them to just forget it, I wasn't paying that. They said OK, they didn't have the part anyway but if I changed my mind they could have it the next day.
When I picked it up they charged me $105 "diagnostic fee" because I had asked them to check it. Of course that would apply to the $399 if I decided to let them fix it within 30 days.
Came home and did what I should have first, checked for this problem online. And there must be thousands out there with the same problem. Always the wires just break off. Even found a couple of youtube videos on how to fix it. And to top it off, this part says "Made In China" right on the box. And can be bought online for $39 (genuine GM part).
I don't know when I have been so steamed that GM would put this cheap Chinese junk in their Premium vehicles and then charge premium prices for replacing them when they fail. And evidently it's not a matter of if, but when they will fail.They need to be replacing them for free, and source from some place capable of making a quality part.
  • 3 years later...
Here is one though on this that i would like some help. I just replaced the haptic motor and the message is still there. Should I get another one for the other side or is there a module that it could be?  2014 Silverado high country. Thanks!
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
