Android Auto info?
Jsmith86
Can anyone point me in the right direction to get some info on the Android Auto feature. I have a 2014 Z71 Silverado.
Is there any benefit to me getting the android auto app since I drive a 2014 truck?
ok, thanks
I just responded in your other thread. The 2014/2015 can not be updated through software to get CarPlay or Android Auto. There are 2 guys on these forums that can get you the 2016/2107 hardware and software with the updates. It is plug-and-play but not exactly cheap.
You can download Android Auto and just use it on your phone. It is a good way to have navigation via Google maps, hands-free phone calls, and any music app organized in one place. If you have bluetooth, the audio will play on your radio. One thing I like on using it just on the phone as compared to my radio is that I can use the satellite view instead of only having basic maps on my radio. But I still prefer to use it on my radio even with basic maps because the radio screen is much larger than the phone screen...
This guy is exactly right. The app also makes the icons bigger and easier to hit while driving. If you have a mount for your phone, it could be perfect. It's a free app, no harm in trying it out.
But it will only project onto the radio screen if you have the Android Auto feature in your truck. This is what the OP asked about is ONLY available on the 2016/2017 (you can get it on 2014/2105 if you go aftermarket).
Or buy the OEM kit from MVI. I have it in my 14 All Terrain. I thought it was a cool thing to have before having it and now that I have it I've probably used it 5-6 times. Google maps is the best part. If there were more apps that were compatible I may use it more often.
What does it cost to get the kit from MVI?
Roughly $1000. I got the factory nav, android auto option. I've seen just the android auto versions for $700 online.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 449 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
