Largest Tire Size Possible on Factory 17's??
My '15 2500HD has the factory aluminum 17's on it, but the stock 265/70/17 (optional Bridgestone Duravis) are too small in my opinion.
I've looked all around this forum, but it seems everyone is either running 20's or 18's. Down the road the polished 18's will go on, but for now... I like the 17's.
Truck is a Double Cab/Standard Bed Z71... not sure if that makes a difference with ride height/rake compared to other trucks.
I don't want to lift or level, I already have trouble fitting in my garage!
Yep, as stated, even a 285/70/17 will look better than those stockers.....but my vote would be for the 285/75/17. I had the dealer switch over to that size before I even drove the truck off the lot, haha.
Did you crank keys? Rubbing issues? I am staying stock wheels and no level myself.
Nope. I drove the first 5000 miles with everything completely stock (except for the tires). I never heard anything rub, even with the GM mudflaps. That being said, I bought the truck after hunting season...and that's about the only time I do any "off-roading" to speak of. Someone with a more adventurous driving style may have been able to get them to touch the fender liner, but I didn't. There was actually more room than I expected. I thought I might have to crank the bars a few turns before I drove it home, but that wasn't the case. There are pics in my build thread if you want to see how it looked before I changed the wheels and cranked the bars.
Thank you sir. Nice set up
No problem! And, thank you! :thumbs:
Edit: We'd also like to see some pictures when you get your new tires installed!
  • 4 weeks later...
What tires did you have the dealer install? I've always had good luck with Bridgestone on my previous vehicles... but then again, I came from driving a 1995 Caprice and 2012 WRX to my new truck. So I'm not sure what the best brands are for 3/4 ton trucks...
Not sure if you were asking me, but I'll respond anyway, haha. I decided on Falken Wildpeak AT3W's for my new HD.
Basically, I'd recommend a good all-terrain tire from a known manufacturer, in a load range E, with a mileage warranty. Examples off the top of my head would be Falken Wildpeak AT3W, Cooper Discoverer AT3, Nitto Terra Grappler G2, Yokohama Geolander G015, and Toyo Open Country AT2.
Thank you, I appreciate the answer! Like I said, I come from driving a totally different type of vehicle so tires for an HD truck I have zero idea about.
No problem! And if you let us know your rim size and ride height (stock, leveled, lifted, etc.), we can give you a few options on tire sizes too.
    Sdid
    Sdid
  • Who's Online   7 Members, 0 Anonymous, 1,489 Guests (See full list)
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
