Strange AC issues (not condenser issue)
zmnypit
I'm experiencing some weird issues with my AC and its cant figure it out. Truck is 14 Sierra All Terrain. Below is a timeline of whats going on:
8/10- AC worked fine that morning, truck sat outside all day until around 4pm. AC never would get really cold on low for the 15min drive.
8/11- AC blew hot that morning for around and hour. We stopped ate breakfast then when I started the truck the AC was working and worked the remainder of the day. I figured a recharge was needed so I attempted to do so. While in the driveway the fan was running wide open, louder than I have heard it before and the compressor was kicking on/off on/off. I added some r134a until the gauge was in the green (55psi or so) and the compressor kicked on and stayed on. Problem solved right? Nope.
8/18- Truck sat in the basement for a week as we were on vacation. That afternoon I went to get gas for the lawn mower and wouldn't you know it the AC blew hot the whole time, I popped the hood and the compressor clutch was spinning and the fan was extremely loud again. I thought great, I have a leak and it all leaked out from sitting. Checked the refrigerant again and its still where I left on the gauge.
8/21- Went to lunch and once again no cold air with extremely loud fan. On the way back home it started getting cool but not like it should be. Just enough to make the ride less miserable. After I got off work I went to check for the condenser leak which came back negative and the AC was ice cold, clutch was spinning and the fan was at a normal speed. Picked my daughter up that afternoon and it worked great even sitting in the driveway running it was freezing.
8/22- Start it this morning just out of curiosity and its back hot.
Anyone have any thoughts? There seems to be no rhyme or reason as to when its going to work or not work. I cant seem to find any leaks and the clutch is spinning at all times now so Im lost.
Maybe the problem is the compressor, not the clutch, is your truck still under warranty?
Unfortunately not. It hasn't worked in a couple days now so It has a leak or like you mentioned the compressor is bad.
Just added dye and looked it up and down for 30min and never could spot a leak. Let some air out of the lines to around 38psi and compressor kicked on and stayed on. I know this wont fix it as I duplicated this the other day.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
