Opinions on suspension lift
berteras
Looking into suspension lifts, my goal is to lift enough to clear 35's without having to cut much. What lift is the best option for a 2017 Silverado 1500? I was told fabtech made a good lift but I read through the forums and I have seen good and bad on those so what else would you guys recommend. Thanks in advance
Just look at the sticky threads a few posts up. The suspension lift thread is dedicated to just that theres a few pages for you to read through
. Yep, more than a few!
Want one you won't have to worry about and will drive better than stock? Most likely won't even have any cutting.
BDS/Zone 4"-6" lift, with Fox/King/Icon 2.5 Reservoir Front Coilovers/Rear Shocks
You'll easily fit a 35x12.5x20 or similar tire with the correct wheel offset.
You'll also need 1.5 or 2" wheel spacers for the rear wheels since the front's track width will get wider from the lift.
Don't go Fabtech, Skyjacker, Rough Country, etc. They're normally glorified spacer leveling kits if 3" or higher.
