2014 LT silverado. Headlights will only turn off if it's in park. I'm tired of blinding people on the boat ramp. How can I make the actual off work on my knob?
Roll the dial left and it will spring back to auto. A message should appear on the dash screen saying auto lights off.
Assuming you're loading/launching in the dark, maybe try turning your dial to parking lights. (Haven't tried this myself, but I'd assume the headlights would come off)
If your truck is or was Canadian, you are stuck with it unless you can get the BCM reprogrammed. My dealership said I would probably end up needing a new gauges cluster and all with a new BCM. I believe it's the law I Canada for lights to be on unless in park.
I read on this forum or another where a member swapped pin connections with his parking/amber lights and I think that's what I'm going to do because they come on automatically at night with the headlights, so the only change will be that they stay on all the time and not the headlights. I really hate for them to be on all the time when I switch to HID's.
I have a Canadian silverado and it sucks that I can't turn off the headlights! :/ you can turn them off while in park though, just turn the dial to the left like everyone says ;)
The Canadian trucks (if brought to the States) can have the lights turned "off"...it's a simple programming issue that can be done by the dealer, I had a Dodge 2500 from Canada with the Canadian version of DRLs, the dealer simply turned that off.
  • 3 years later...
Tried turning off the main headlights during a heavy snowstorm because the headlights weren’t  projecting far enough and were just “highlighting the falling snow directly in front of the truck, tried to turn them off to use fog Lights hoping it would be better to see. On a dark road with no street lights and heavy snowfall, i could barely see in frontof the truck. This is a problem as i live in Michigan and needs to be addressed. SOMEHOW.  Practically blind!!
still love the truck... just cant drive safely in snowstorms .... on a dark road .... at night!
update: Chevy does not allow trucks manufactured for use in Canada to be reprogrammed or modified. Basically im stuck with it!?
Edited by Steve R
Updated
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
