I bought a 2000 silverado 2500 6.0 harder with 4wd, but the previous owner had removed the front cv axles because he had broken one. I have replacements, but do not have the bolts that hold the axles to the differentials. There are 6 of them on each side.
I need to know the length, size, and thread so I can buy new ones. I have tried searching but can't find the information anywhere. I also can't find anywhere that sells the specific bolts.
Any help would be greatly appreciated.
This is one of those things I would consider buying at a dealer...
With that said, I would get a handful of metric bolts from the local hardware store and figure out the thread and length, then hit up a specialty fastener shop (fasenal) and see what they recommend for hardness.
  • 5 years later...
You guys were a ton of help let me tell ya.... you literally did NOT answer the question that was asked, if you don't know yourself the DONT reply to the question..... DUH...🤤
  • 1 year later...
Did you ever figure this out? Currently having same issue. Can you email me if so? [email protected]
Thx so much
  • Sad 1
Thx so much
Don't see the part number listed on several of my trusted sources.  They might be called Flange Bolts and I know they are torqued to 58 foot pounds.  If memory serves they take a 15mm socket.
Call your local dealer with the last 8 of your VIN.
They MIGHT be 26036835.
  • 1 month later...
M10X1.5X25mm
M10X1.5X25mm. Just had this exact thing happen to me today, somehow all 6 bolts wandered off. Thankfully no other damage. But me posting this will help a ton of people I’d hope!
  • 11 months later...
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
