Trim Removal Tool(s)
Before I got my set I used some plastic spackle/drywall tools. They would break a lot, but never scratched anything. Just a thought if you are having trouble finding them.
Glad I wasn't the only one who was thinking of doing that as well... But those can be a lot more expensive to replace :)
If anyone else is on the fence about getting a trim removal kit, I must say, it was well worth it!
I ended up buying this one online: https://www.amazon.ca/dp/B00ORNEQBA/ref=pe_3034960_233709270_TE_item_image
I was using it simply to push cables into tight spots on the trim as well as pull out the trim a bit to push the cables in-between areas. This set worked great, was strong, and was cheap. There were a couple of times when my hand slipped and could have done some damage with a flathead screwdriver that I usually use. So glad I bought this - Thank you all for your suggestions and recommendations!
