Center console organizer tray for Colorado / Canyon
Hello,
Any interest in a center console organizer for the Colorado / Canyon trucks?
Salex Organizers manufactures Vehicle OCD™ center console organizers. We offer center console organizers for the full size GM trucks and SUVs. I get occasional requests through email and recently on the Facebook page to design an organizer for the Colorado / Canyon.
I would like to hear from owners to see the interest level and any requests or comments on the design.
UPDATE - January 2018
The Vehicle OCD™ for the Chevy Colorado & GMC Canyon is complete and available to order.  https://www.amazon.com/dp/B0773S1MF2
Hmmm. Would this I assume be for the center bin (the armrest is the lid)? Obviously not that little forward cubby in front of the shifter...
Sounds like a nice feature. Its a deep bin and all, but it would be nice to have a higher up spot to stash things in. I'd be of interest. My only design suggestion would be to keep clearance for the USB in the bin. I use that one for my iPhone charge cord as I love the fact I can tuck the whole cord in the console and just leave about 6-8 inches of it hanging out. My phone sits in the tray right in front of the console. Also, I wouldn't want one that is really deep per say, as to keep clearance for anything larger underneath it.
Yes, the center console. When you lift the armrest the tray stays with the lower console. The tray for the full size trucks is 2" deep. That is a good depth for phones, wallets, glasses, pens, gum, etc. Leaving access to the USB port would definitely be a feature. Thanks for your feedback!
Please email [email protected] if you would like to be notified when product is available.
I will post updates here and on Facebook as things progress. Early 2018 is best guess on availability at this point.
  • 4 weeks later...
Looking for some feedback from Colorado / Canyon owners.
I have a 3D printed part for the new center console tray due tomorrow to check fit.  The attached picture is showing the tray with a rubber mat in the bottom.  The tray will be black along with the rubber mat.  I have it gray just to see the mat in the bottom.  The tray is 2.5" deep at the back.
I would like to get feedback on dividing the tray into compartments or leaving it open like shown.
14 hours ago, wahudiditagain said:
Hope this is still an option. I had a Salex  in my Tacoma and have been hoping for one for my Colorado.
It's in process.  Any thoughts on dividing it up or leaving it open like the picture shows?
The feedback I have received was almost 100% asking for compartments in the tray.  Take a look!
Looks like I January 2018 availability.
  • 3 weeks later...
Just another update.  Email response has been strong.  As you all know this is a product that has been missing from the market.  Availability is still January 2018.  Price will be under $20.
Follow Salex Organizers on Facebook and keep up with this product and other new products.  The Vehicle OCD™ organizers make great inexpensive Christmas gifts.
  • 3 weeks later...
Hello again,
Here is the 3D prototype in a 2018 Chevy Colorado.  It is a perfect fit!  Things are still tracking nicely for January availability.
Shoot me an email at [email protected] to be notified when available.
While you are waiting you can do some Christmas shopping.  Chose from over 40 Vehicle OCD™ procducts.  Unique, useful, American made Christmas presents!
  • 1 month later...
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
