Right rear tail light
T75irl
Right rear tail light works when brake is applied but does not when the brake is not applied. Bulbs have been changed on all three lights (both sides). Continuity is good on both sides. Any help is greatly appreciated.
Respectfully,
Tim
Electricity is funny - it will make all kinds of strange things happen while finding the path of least resistance back to where it came from.
When weird stuff like this happens, the first thing I look at are the bulbs. I've had many strange problems caused by a burnt out and bridged filament - on a 1157 bulb or the newer 3057, the tail light filament burns out, then makes contact with the brake light filament. I had one that still worked normally (when not compared with the other side - was much dimmer) but would light the front marker lights whenever the brake was applied. Bulb change fixed it. Since you already changed yours, this MAY not apply ... but I always suspect ANYTHING new these days.
Some of the cheap bulbs can be installed the wrong way (brake activating tail, and vice versa) even though the pins are at different heights (showing my age here). With your vehicle, you've probably got the flat base bulbs, so this wouldn't apply, but I've seen wire at the base come out of place, or break, and short to the other segment a few times before. Long shot, but worth a look anyway.
Ground issues can also cause some strange stuff to happen. Could be that the ground for the tail lights is bad, and is finding a ground through the bulb, & through the brake light circuit.
Continuity is one thing, but will it carry a LOAD on the circuit - that is the question.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
