Help getting rims !
I know it's a long shot but I'm really wanting to purchase these and I'm putting this out here to see if anyone currently is selling a set and or Knows a good website to purchase from ! Appreciate any help
Sent from my SM-N950U using Tapatalk
Try eBay and Amazon, but the dealer seems like the best spot.
I don't see the rims I showed a picture of . Did you see it ?
With hundreds and hundreds of rims on their site, I did not take the time to look thru them all. If it's an original GM wheel, they "Should" have them.
Sent from my SM-T817V using Tapatalk
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
