Sarge
Robert Lee
Hello
I'm Robert but I'm known as Sarge.  New to forums.
Drive 2001 Yukon D XL 135,000
Slowly brining her back to life.  Previous owner used and abused her.  Had her a year now..just about new everything.  Shes my beast of burden but destined to make her showroom again.  Look forward to spending time in here
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
