Quieting That Annoying Seatbelt Alarm?
PeteCress
I just did a bunch of research into GM seat belt pretensioners.  The devices in our trucks are the shoulder belt pretensioners, and not buckle or seat-mount versions.  These are controlled by the sensing and diagnostic module (SDM), which controls airbag and pretensioner deployment; thus would not be affected at all by disconnecting the sensor at the latch.
They were however, the reason all our trucks were recalled for a software update to the SDM.  I suspect what happened to you was the result of the defect causing the recall, and not that latch wire.
On 11/10/2017 at 3:49 PM, PeteCress said:
That sounds like the ticket to me: no trip to the dealer, no chance of disabling the airbag....no other unintended consequences.
Until seeing the pic in the line, I had assumed that it would compromise my use of the seat belt, but now I see it's transparent use-wise.
Thanks!
Did it.
It's been a couple weeks now and it is working exactly as expected.
Only mod I made was a few inches of Gorilla Tape between the extension and the GM part to prevent my fingers from finding the wrong release button.
7 hours ago, MaverickZ71 said:
I figured out how to do that when my truck was new.  The loud warning chimes come from the driver's door radio speaker, and I was so proud of myself for turning those danged annoying chimes off.  Then a few days later I hit a relatively minor ridge/crack in the road (the roads here are about as good as beautiful downtown Kabul) and there was a loud bang by my left ear and my seatbelt got tighter, and there was an airbag warning light.  The airbag light went away after a couple of starts.  I now think the seatbelt pretensioner fired--it sounded like a .22 round going off behind my head.  I plugged the seat belt wire back in under the driver's seat and haven't had any more issues.  In my experience, every time you try to out-think one of these new GM vehicles, it comes back to bite you in the behind later.  Another thing that gets me is if you use the keyfob to remote start the truck, it does the warning chimes and red seatbelt warning light before you even open the door to get in--to warn any ghosts to buckle up, I guess!  :uhoh:
If the seat belt pre-tensioner actually did go off, you probably should replace the seat belt mechanism - it's part of the repair process after an accident.  They pre-tenioners can go off even if air bags aren't deployed.
    Bert 22
    Bert 22
  • Who's Online   2 Members, 0 Anonymous, 653 Guests (See full list)
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
