Humming noise
2017 silverado 5.3 with 3:42 gears. So i’ve been having this issue with a humming noise that starts around 40 and is heard up to 75 mph. It literally showed up one day on the way to work on the highway. Truck had about 7,000 miles on it and the weather just turned cold. Sometimes its rythmic(4 seconds of noise then no noise). Sometimes its constant. Coming from front driverside. Can barely feel it in my feet when it occurs. The kicker is when i hear it i can put it into 4wd auto and the noise immediately goes away. If i drive for about 15 miles of highway the noise will also fade out if i dont do the 4wd auto trick.  I’ve done some searching and saw a forum about this issue back in 2015 but cant really find anymore about it. The forum also said it was a front differential issue and guys were having them replaced after a lot of battling with gm. Most said the noise came back after 1000 miles of having the diff replaced. Any help is appreciated with this. I’m trying to get all the info i can before i do the service manager shuffle.
  • 2 years later...
@Ryan2828 did you ever get this sorted? Same problem on my 2018 - in 2wd rhythmic hum coming from front drivers side. Only in 2wd; if I switch to "auto" the noise stops; switch back to 2wd and there it is again. Seems to happen between 70kmph+... trying to work with a dealer now to figure it out. So far theyve changed transmission fluid and done an alignment but no luck.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
