No start issue - bulletin
COP TZR
Noticed a delay in engine starting up, would roll over a little longer than normal the past week or so, thought it was the drop in temperature or maybe due for plugs at 60k. This morning it was -25degC/-10degF and it would just roll over and not fire. Tried several times, no go. Went back out 15min later and it started, then engine light came on. Plugged in reader and had p1682 code. With it still being under warranty took into dealer and had them make record of it and to diagnose. Well I got a surprise when my total was $59.59 out the door for diagnostic check, parts, and labor. 3yr bumper to bumper had expired, still has 5yr powertrain. This issue NOT covered under warranty.
Quick summary:
2014 GMC Sierra 1500 5.3L 60k
Tech comments:
verified complaint, no start, vehicle eventually started, scanned for dtcs, p0689 engine control ignition feedback circuit low voltage, p1682 ignition 1 switch 2, found bulletin #PIT5253B, replaced relay #70 ecm as per bulletin, also checked battery, battery tested good at 625cca, cleared dcts, all ok.
Parts:
1.00, 13595508, Relay, $11.99
Put half a bottle of synthetic slick 50 in the motor oil. It will leave enough lube on the motor parts to start. This zero weight oil is leaving nothing on internal parts....excessive amp draws from battery on cold starts and not good for negative and positive battery leads.
Try it. Mine starts MUCH easier now.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,140 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
