Quick Decal question
mac3897
Hi all. This will be my first post. So be gentle to the newbie.
I have noticed that on Chevy and GMC trucks that there is a different Z71 decal on some.  Some have the words "Off Road" under the z71 and others do not. I though the Z71 option was the "Off road" package.  Is there a difference?
Just curious.
I believe the decals changed around the same time the 4th rear door became standard on the Extended cabs (approx. February 2000)
Any relation between the two? Probably not. The General just changed the decals I think. (For the better IMO)  :D
there are some 4 door trucks out there with the older style Z71 sticker look at http://www.picturetrail.com/bco
his truck is a 2000 4 door with the z71 no offroad.
Hey Ryan - long time...
Yeah, the 4th door was an option until Feb 2000. It was standard equipment on the ext cabs after that. Years after it was standard on the F-150  :angry:
Welcome to the forum Mac:
The difference between the ones is the year of the truck, I think in 2001 they switched from the Z71, to the Z71 "Off Road" Decal on the truck.  If you've got the old style sticker you can always buy the new ones and put them on.
Jon
my truck is a late model 2000 and have the newer sticker (came from the factory like that)
Thanks for the replys. I have the "Off Road" version. I was just curious to see if it had anything to do with getting any of the other option packages with the Z71 package.
Mac
Jon
Same here Ryan, I think our trucks were both 'born' in April 200 if I remember correctly.
It was a mid-year 2000 model year thing.
I think GM added the "offroad" to the decal to justify the price increase from the '00 to the '01!!!  LOL  (just kidding)
I think theses guys have already answered your question.  Welcome to the forum!!!
muahaha!!  it will be awhile before you guys get a sunroof, dvd player, and heated cloth seats.  :D:D
Why don't they just leave the trashy looking stickers off our truck, and charge us $5.00 less?   :sarcasm:
I removed the 4X4 sticker from my bedside!!!
Paco, we get a DVD Player option w/ the bose stereo for 2003.IM000275.JPG
:D
So there you go, for once I'm right.  And who needs heated cloth seats?  Cloth doesn't get cold, especially base model cloth :D
