will 03 front door panels fit 02 silverado?
They should.  I put a front door and front fender from an '01 sierra on my '04, and everything lined up and fit.
The only differences I found were:
-new interior door trim has 2 extra things to hold it in place vs older '01 trim (bolt in back edge, push-in plug in front edge)
-new fender has 2 extra nuts welded to inside of fender to attach a brace to it just below hinge mount that the older '01 fender didn't have
Note:  If you are buying  a take-off door of the same color to put on your truck, make sure it is the same color (verify the color code in RPO code list is the same as the one for your truck), and if possible, prop it up next to the truck and verify it's the same shade.  I made the mistake of the 'silver' being the same for the whole range of years...it's not...
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
