Which Brakes for Towing?
So my brakes are totally shot on my 2005 GMC 1500 SLT 4x4 crew cab.  I have disc brakes up front and drums in the rear.  The front are squeaking and the rears are making crunching sounds.  I've never changed drum brakes/shoes before (is there a good tutorial somewhere?).  I tow often in the summers, a ~6800lb loaded 29ft camper, so I need good brakes.
What brands does everybody use?  I was running Wagner pads and rotors, which I've normally had success with, but these didn't seem that great.  Do you guys stick with AC delco?  Ceramic or semi-metallic?  What about the Prostop rotor/pad kits, are those a good brand?
Thanks for any input.
I just went to the Powerstop drilled and slotted rotors on the 01 1500.I have ran their products before on cars with great results. So far I have about 2000 miles on this set and I LOVE them.
https://www.powerstop.com/product/power-stop-z36-kit/#y=2005&mk=CHEVROLET&mo=SILVERADO 1500 4WD&ss=with rear drum brakes
They do not have anything for the rear drums.
My 01 has 4 wheel disk brakes.
Youtube has a tutorial for everything...
https://www.youtube.com/watch?v=fRc7dF4haIE
Thank you, I may just go with power stop then!
  • 3 weeks later...
I've got the power stop Z36 kit on order for the fronts, thanks for the recommendation!
What do people normally do for drum brakes?  Do you just change out the shoes, or do you change out the drums normally too?  Any recommended good brands for the rear brakes?
Power Stop pads and rotors are awesome! I've been selling them for over 15 years now. There drilled and slotted rotors will drop the brake temperature as much as 200 degrees. But, as I always tell my customers, the pad or shoe set is only as good as the installation!  So many times I get customers who just want to 'slap' a set on without any further work. Not cool. Power Stop pads are known for "low dust and no noise", but only when a brake job is done correctly. For the customer who is just going to put pads on without turning or replacing the rotors and checking there calipers, I sell them our $16-$20 pad set.
For a thirteen year old truck the drums should probably be replaced.  Some shops might still be around to turn them if they are still within spec but it is less expensive and time consuming to get new ones.  My preference has been OEM or Bendix.  Replace the hardware too.
Thanks for all the good recommendations everyone!  I'll look into just replacing the full drums, shoes, and hardware.
Stupid question, I'm guessing when you order the drums online, it's just a bare drum right (no shoes or hardware)?  Or can I order a complete kit, like the rotor/pad kits?  I'm not seeing any drum kits on rockauto.
Unlike your Power Stop Kit, you will need to buy it all separate. Check with your local Napa, etc before you order it online. Might be cheaper with the freight prices on the drums. And check Amazon if you are a prime member.
    250.3k
    Old Bay
    Old Bay
  • Who's Online   4 Members, 1 Anonymous, 924 Guests (See full list)
    • I know when I was looking around last year to see if someone handled Amsoil gear oil to buy at the retail level which of course means full price. I found an independent shop that works a lot on GM/Duramax pickups and they did not bring in the 75W-85 as they just stuck to the 75W-90 for the front and rear as a standard practice for the HD trucks which makes sense anyway for the higher hp/torque diesel and pulling heavy loads in four wheel drive. I haven't changed my diff oils yet but still plan on using the 75W-85 for the front diff as I highly doubt I will be beating on the truck and figured for my use type the bit thinner oil would be to my benefit for the winter for that slightly less drag. Very different weather here all winter vs northern Washington near the coast, that's for sure.
    • Ok that confirms the extra quart theme they are still going with which must mean they have noted some initial use more so then some engines and probably the bigger factor in all of this probably isn't the engine so much as its the insane distance or OLM that lulls a lot of the driving public into driving their new vehicle off the lot and not even doing one short interval oil change because the manufacturer doesn't say different and if the dealer follows that logic as well. Selling the rarely needing to be serviced concept seems to go over well with the public that wants to get away with as little as possible for dollars spent on the vehicles maintenance and I bet there are 3.0 engines just like other vehicles out there that never have their oil checked by the owner which goes back to why they probably felt the need to add that extra quart to avoid a costly theme.    Speaking of cutting filters open, it was probably over two years ago now that a youtuber who buys vehicles to do longer term reviews and pulls a fifth wheel through the mountains of Colorado on summer trips and that becomes part of the testing. Anyway he had a GM HD with the 6.6 gas and a Ford 250 with the 7.3 gas at the same time and of no surprise the Ford had more power etc but somewhere along the way in the few thousand miles he put on the truck, he changed the oil and was seeing glitter and cut open the filter and yeah, things were not looking spectacular. The truck about that time or soon after seemed down on power compared to what it had been and then threw some engine code, I expect the cam/lifters were failing and so he brought the truck back to the dealer and made some deal to get out of it as he knew it would sit for months waiting on a new engine as they were so backlogged at the time. He kept the GM for some time after that using it exclusively until he sold it after buying his next vehicle to do a review on. Definitely the filter can tell a story when things are starting to go sideways, but it would be a sickening feeling to cut it open and be faced with an ugly mess like that and be running a magnet through the pleats and the oil on the dirty side of the filter and see all the fines sticking to the magnet.    The dealer may have some ideas based on experience as to where that coolant smell is coming from, I would imagine if they can't find it but its smelling they would put dye in it to they could give it a run cycle and use the black light to see where it pops up, if its a hose connection, water pump, rad or even a head gasket etc.
    • Good looking truck, suspensionmaxx looks like a solid option
    • Thanks for the info, im considering a leveling kit or 4" lift kit.
    • charm.li (website) has the vehicle-specific diagnostic procedure for that code, you can use to find what the cause of it is.
