Lifter Rattle
geswek
23 minutes ago, Bwoodkid said:
my !5 did the same thing with the 91/92 tune, pretty sur its a bit of knocking. I let Diablew know about it. He adjusted my tune and it was fine.  make sure you use the higher of the octane and good gas. if you can.
I've been in talk with Lew and I still have hard time believing that is the problem. He denies it is not the tune and that it is in fact fuel--I've checked everything from cracked manifold to cat.
I bought the 87 octane because all I wanted was DOD to turned off and my tire size set right. The added power was just a bonus. I reloaded the tune, boosted my octane (had 87 in there) and fill with 93. I'm going to test this and then drop down to mid-grade and go from there.
On ‎2‎/‎10‎/‎2018 at 3:35 PM, geswek said:
Good news.
I can’t replicate it now no matter what I do.
I’m assuming what I heard was actually spark knock which sounded like someone shaking a paint can.
not enough octane in the gas was my first thought from your first post. I run 93 or E85 in mine when using the 91 octane tune from superchips just to make sure theres enough octane
  • 1 month later...
6 minutes ago, Spastik Monkey said:
Check the engine tick thread. I have the noise and AFM is disabled in my truck.
It's gone away; I've been running mid-grade fuel for about a month and the noise never happens.
