On 10/5/2019 at 4:23 PM, Bash74 said:
Have the dealer take a look at the in tank fuel pump. I was there when they pulled my out and it was falling apart. Contaniments end up in the whole system and messes up injectors and high pressure fuel pump. Mine wasn't the first one to be like this they had to deal with. So now when injector is a problem it's the first part they check as part of diagnosing. My fuel pump, high pressure pump, rails, and injectors all replaced. My warranty covered it all.
Sent from my SM-G935V using Tapatalk
This is distressing.
  • 4 months later...
I’m having an issue now with my 2015 Sierra. Code reads cylinder 5 misfire. I’m at 118,000 km. It’s not considered power train so no warranty. The quoted me 1890.00 plus taxes for all 8 injectors. I service my truck more than gm recommendations , shouldn’t have this issue.
I was thinking just to replace the one that’s bad but only $500 more to do them all and be done with them.
could I save money by going elsewhere to an independent garage?
Servicing your truck has nothing to do with the fuel injection system. With fuel as terrible as it is right now, If you don't put a injector cleaner in your vehicle every so often, You will have bad injectors. Just the way it is.
Check out this vidoe on how to replace them and just do them yourself. I am guessing you're in Canada or something like that with km. So goto your local auto parts store, Pick up all the injectors and then goto a dealership and get the 2 fuel pipes and do it. It's an easy job.
here is the problem with changing just one. You have to remove the fuel feed pipes. When you do that, They have to be replaced. If you change just 1 and then another goes out, You are just throwing money away. Those pipes can not be reused and if you try, they will leak. Trust me.. I have tried multiple times to try to save them for people.
Here is the video.
On 9/30/2019 at 10:59 AM, TJay74 said:
Eff that, $2600 is some serious up charge. The injectors are only around $65 each and are not that hard to change. I can have the intake manifold off in less than 30 minutes and the injectors changed out in an hour. The only other thing you might need would be the 2 hard line fuel cross over pipes and the intake manifold gaskets. All in parts should be less than $500 and no more than 3-4 hours of labor.
Any shop (mom/pop or dealership) should be more than capable to do this work, I have done it in my garage several times now.
I can't find OEM injectors anywhere. Do you have any experience with Echlin Injectors from Napa? I want to replace all 8 myself but they say I need a special sizing tool for the seals....is this true?
I had the same problem but would not give up as there is no way you should have to change injectors. It took 6 months but finally remedied. I switched to Chevron fuel and used numerous fuel injector cleaners and finally "Gum Out" worked. I don't get anymore codes and everything works fine now. I also had transmission problems as with the engine running rough the transmission kept trying to relearn itself and that has gone away now too. Hopefully this helps someone as GM wanted $2700 to just replace injectors and they couldn't figure out the transmission problem. GM was figuring I needed a new transmission.
    doylej24
    doylej24
  • Who's Online   2 Members, 0 Anonymous, 664 Guests (See full list)
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
