On 10/5/2019 at 4:23 PM, Bash74 said:
Have the dealer take a look at the in tank fuel pump. I was there when they pulled my out and it was falling apart. Contaniments end up in the whole system and messes up injectors and high pressure fuel pump. Mine wasn't the first one to be like this they had to deal with. So now when injector is a problem it's the first part they check as part of diagnosing. My fuel pump, high pressure pump, rails, and injectors all replaced. My warranty covered it all.
Sent from my SM-G935V using Tapatalk
This is distressing.
  • 4 months later...
I’m having an issue now with my 2015 Sierra. Code reads cylinder 5 misfire. I’m at 118,000 km. It’s not considered power train so no warranty. The quoted me 1890.00 plus taxes for all 8 injectors. I service my truck more than gm recommendations , shouldn’t have this issue.
I was thinking just to replace the one that’s bad but only $500 more to do them all and be done with them.
could I save money by going elsewhere to an independent garage?
Servicing your truck has nothing to do with the fuel injection system. With fuel as terrible as it is right now, If you don't put a injector cleaner in your vehicle every so often, You will have bad injectors. Just the way it is.
Check out this vidoe on how to replace them and just do them yourself. I am guessing you're in Canada or something like that with km. So goto your local auto parts store, Pick up all the injectors and then goto a dealership and get the 2 fuel pipes and do it. It's an easy job.
here is the problem with changing just one. You have to remove the fuel feed pipes. When you do that, They have to be replaced. If you change just 1 and then another goes out, You are just throwing money away. Those pipes can not be reused and if you try, they will leak. Trust me.. I have tried multiple times to try to save them for people.
Here is the video.
  • 3 weeks later...
On 9/30/2019 at 10:59 AM, TJay74 said:
Eff that, $2600 is some serious up charge. The injectors are only around $65 each and are not that hard to change. I can have the intake manifold off in less than 30 minutes and the injectors changed out in an hour. The only other thing you might need would be the 2 hard line fuel cross over pipes and the intake manifold gaskets. All in parts should be less than $500 and no more than 3-4 hours of labor.
Any shop (mom/pop or dealership) should be more than capable to do this work, I have done it in my garage several times now.
I can't find OEM injectors anywhere. Do you have any experience with Echlin Injectors from Napa? I want to replace all 8 myself but they say I need a special sizing tool for the seals....is this true?
  • 1 year later...
I had the same problem but would not give up as there is no way you should have to change injectors. It took 6 months but finally remedied. I switched to Chevron fuel and used numerous fuel injector cleaners and finally "Gum Out" worked. I don't get anymore codes and everything works fine now. I also had transmission problems as with the engine running rough the transmission kept trying to relearn itself and that has gone away now too. Hopefully this helps someone as GM wanted $2700 to just replace injectors and they couldn't figure out the transmission problem. GM was figuring I needed a new transmission.
    Ryanwehr14
    Ryanwehr14
  • Who's Online   6 Members, 1 Anonymous, 414 Guests (See full list)
    • There you go again.  Preaching your politics and worse case scenarios.  And what are you doing to make the world less polarized?
    • Maybe.   Maybe.   I don't want to be the one that needs help and can't get it when I need it. That is a legitimate complaint, and how they respond to those legitimate complaints is a big red flag to me.   I don't care how good the product is their conduct is subpar. Some people are fine supporting that for the sake of getting the product they want. I'm not.   To be fair, I haven't seen or touched their product in person to determine for myself the quality of it. I'm not offering any opinion on that either.
    • So if you do nothing and they act on their threats like death to America or Israel. And possibly a nuclear war. Whoever survives wonders why didn’t they listen? Or we do something like every President has said they can’t get a nuclear weapon. We’re at the 10 yard line and it happens the time is now or never. I think I’m ok with paying a little more for gas for awhile. It’s a shame that we now live in a world that’s so polarized.
    • 4-5-6 fails due to design.  Not enough clutches and not enough piston to clutch surface area.  Also the backing plate can bow.     I'd say converter is two part.  The design of converter chosen, and factory tuning of it aka slipping it in D (also L6) for AFM purposes, as well as locking it up in 2nd gear, sometimes 1st, also it will partially lock up at light loads.  All because CAFE/fuel economy requirements.  A billet converter on the stock tune might hold up better, but would still be subject to the stock tuning and how its designed to lock or partially lock.     The most baffling part to me, is the 2007-2013 6L80s didn't have the failure rate the 2014-2018 ones do.  I've been where I work for almost 17 years now, and I recall maybe 3 or 4 of the 07-13 transmissions getting pulled for something.  14-18 on the other hand, it was at a minimum one a month being opened up.    If I had to guess, I'd say the tuning for the gen 5 engines/6L80 setup and its fuel economy goals had a good bit to do with it.  Also, it was bankruptcy time during these years, so I'm thinking some cost cutting was done for the launch of the K2XX trucks.  See also now the 10 speed valve body issues (more cost cutting).  They blow out some mesh screen in the spacer plate, undersized check ball, and the feed limit valve was aluminum and wears out prematurely.         I don't think it was the HP jump from the gen 4 to gen 5?  The 6.2 in the 07-13 trucks was good for 380-400hp during its life/states of tune, and the 5.3 did 310-320hp.
