Fog light option for WT
Revspan
Thanks for the reply.  I am referring to installing fog lights in W/T that has a solid chrome/steel bumper with no openings for fog lights.  Maybe the best option is to purchase an aftermarket bumper off ebay/online and then go through the steps to install fog lights.
  • 4 weeks later...
On 2/10/2019 at 11:57 AM, greatmizzou said:
Fog lights on trucks are useless and only there for aesthetics
Not true at all. Here in Utah at night especially when it’s raining fog lights are a HUGE help in seeing the lines on the freeway. Our lines here don’t have a lot of reflection so they can be difficult to see. My new 18 Silverado 2500 WT doesn’t have them either and my last truck did.  I didn’t think I’d miss them but i was mistaken.
It is just a matter of placement.   Fog light are supposed to be very close to the ground and illuminate the road very close to the front of the vehicle.
most fog lights on trucks are well over a foot off the ground and aim the same area your headlights hit. I remember testing mine in really thick fog and noticed no real noticeable difference, same in my wife’s CRV.   That led me to researching most manufacturers have placed fog lights out of realistic usage.
Ya as for actually helping in the FOG I agree they don’t really help much. But as I said to help see the lines on the freeway they can be a HUGE help. At least in my experience
I have found fog lights to be very beneficial more for seeing the road up closely after dusk.  The term "fog light" appears to be a misnomer.  I agree that most fog lights don't help much for purposes of seeing through fog.  My 2013 Yukon has "fog lights" that, when turned on, do significantly help, in my opinion, light up the road very closely to the front of the Yukon.  Unfortunately for those of us that own Silverado or Sierra W/T models, there doesn't appear to be a good option for adding fog lights if our bumper doesn't have the insert -- unless we want to change out the front bumper or get into a Chip Foose style of bumper modification!
My research has indicated that one can add the 20" LED light bar in the center of the factory W/T bumper, but haven't pursued this yet because I'm not sure how much it will help light up the road and it appears that the light bar is for "off road" use only.
Can anyone intelligently comment from experience on how well the 20" bumper installed light bar works and when it can be used?  Of course we all know there are different qualities of light bars for sale!  I am thinking of a light bar similar to the one in the below link.
https://www.roughcountry.com/20-inch-led-light-bar-70920blkdrl.html
And the brackets for the light....
https://www.roughcountry.com/chevrolet-20in-light-bar-bumper-mounts-70522.html?gclid=EAIaIQobChMI-6SVq6b64AIVlRh9Ch3XGQ-GEAQYASABEgJkKPD_BwE
I think you will have glare issues with oncoming traffic with that light bar in a "fog" application - it appears to have a spot/flood combo beam pattern and the flood portion will likely be blinding.
  • 3 weeks later...
That's what I did. It used to be a W/T.
  • 1 month later...
I've got a GMC bumper sitting in the back yard, think it has holes for the fogs, willing to sell cheap, no shipping....
  • 4 months later...
Hey. I’m having the same problem and thought that where the black plastic on either side of trans cooler would look most factory but can’t find anything. Any ideas
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
