Transmission Issues
IMG_0482.thumb.jpg.199003592ceb03b0416a8389cb22804f.jpgIMG_0481.thumb.jpg.24ca93a598f5ea27cc6e81852c62a452.jpg
17 hours ago, pigphart said:
How is your truck doing after the flash update?
actually doing great... ..drives much better than before.. i can tell for sure.. .and its weird about the gas.. not sure why it went up~.. but all is good!.. just hit 32k!
attached is what they did with the bulletins!
hope that helps man!
Thank you so much, you have convinced me to follow through with it at my dealer.  Cannot thank you enough, just shouldn't be like this on a new truck with no one being able to provide an answer at the dealership.  Seems silly.
Thank you again
  • 3 weeks later...
Thank you again
How did it go?
I had it done, but still banging into 2nd from 1st and visa versa, but not as bad as it was.  Hauled our Jet Skis to the river with no issue trailering but in traffic and stopping and starting it still bumps a bit.  Performance is good, gas mileage was 16.2 for 300 miles to Needles CA which is pretty good considering I'm hauling 2 jet skis and all the trimmings, but the bumping from shifts is really getting old.  I really want to thank you for all your help, it did help but didn't resolve the issue completely.
  • 2 months later...
Well I have an update.  They found that I had a cracked throttle body, which was their answer to my transmission fix for a 4th time.  Since the replacement it runs much better, but the transmission has the same clunk as before.  I'm taking it in again Wednesday to have it looked at again, by the same mechanic that has looked at it before.  I was thinking that I might try another dealership and see if fresh eyes on my problem could be a better option.  Thank you all for the help and especially the hotfix for the computer.  They had NO idea about the software update and literally had to contact GMC for the update.
After a reprogram and valve body my truck still had hard clunking up and down shift in second gear and acceleration was not smooth with a vibration at about 40-50.  My solution was to get rid of this truck and switch brands.  After several GM vehicles, I am no longer interested in any GM vehicle after this.
Bye GM.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
