2018 GMC HVAC whistle
Just purchased a new 2018 GMC Sierra double cab 4x4. All is good except that when the HVAC system is on there is a whistle at highway speed which gets worse as the vehicle speed increases. When HVAC system is off, no whistle. The whistle is worst with the outside air on, fan on high and in defrost only mode. In the recirculate air mode the whistle almost dissapears. GM'S bulletin # PIT 5272A indicates a long outstanding problem although my 2013 GMC had no such issues.  Has anyone else experienced this problem? Was your dealer able to resolve it to your satisfaction? Thanks in advance.
My 2017 Silverado had a slight HVAC whistle that started a few months into ownership (i reported it here last fall).
It had since stopped a couple of weeks after it started so I'm guessing some debris got in there and eventually worked it's way out.
Did this start after taking delivery? Or has it been there since day one?
I would guess some debris is in there. I would bring it in to have it addressed.
Recently bought a 2018 GMC Sierra Elevation Crew Cab in Feb 2018. I've noticed that whistle as well...it has 3K.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
