Throttle Percentage @ Idle
My '07 Z71 has been giving me the P0121 code for awhile and I noticed when I run the live data on my reader, that TP % stays around 25 % when the truck is at idle.
Is that normal? Seems like it should be close to 0% when the throttle isn't being pressed.  What should I check?  I do have a replacement accelerator pedal w/ sensor from AC Delco
Any recommendations are appreciated!
-Brandon
2 minutes ago, swathdiver said:
That's a code for a bad TPS sensor 1 on an NNBS.  You have two right along with drive by wire?
Not sure what you mean by "two right along".
The only one I'm aware of is attached to the accelerator pedal.
Sorry for the poor grammar this morning.  I believe that your truck, like mine, is drive by wire.  No cables going to the throttle body.  If that is correct then you have 2 throttle position sensors.  Code P0121 means the 1st sensor has gone bad and needs changing.
Sorry on my part too, it's been a busy morning.  So the 1st sensor would be the one on the throttle body correct?
Yes, if yours is NNBS, the computer sees that as two sensors.
It is the new body style. I'll try to pick one up at the parts store today
  • 3 weeks later...
Apparently the new pedal fixed it.  Light has been off since replacement.
    mighty K20
    mighty K20
  • Who's Online   4 Members, 0 Anonymous, 564 Guests (See full list)
