LED Tail Lights Wiring Questions
Hey all,
Somebody hit one of my tail lights while I was street parked and I need to replace it, so I figured I might as well get some smoked tail lights since I had to shell out some cash.  I have an LT with incandescent tail lights.
The tail lights I am looking at are these Spyder LED ones in black: http://www.autoanything.com/lights/spyder-led-tail-lights If you scroll down you can see them.
Then I was planning on using this wiring harness to add a load resistor to stop issues from going from incandescent to LED lights. http://www.gen5diy.com/Chevrolet/Silverado/P-P-Harness13/LED-Taillight-Harness/LED-Taillight-Harness9/
However I still need to find a wiring harness that plugs into the tail lights, because I don't think my stock wiring harness will work and the Gen5DIY harness plugs into the one that comes out of the stock LED tail lights.  Anyone done this kind of thing before and can point me in the direction of the right parts?
Thanks!
Spyder makes an LED tail light set that plugs into the existing sockets and has built on resistors. They also make the same tail light for the factory LED setup, with no resistors.
Otherwise you would need to get a different factory harness to go with the Gen5 resistor harness.
Look at RealTruck’s website - they have both models on their page.
Thanks I found the one I was looking for on RealTruck, I'm good to go!
Cool. Let me know what you think if you get them. I'm trying to decide whether to go with the red Spyder's or to keep holding out for an expensive OEM LTZ/High Country set.
    mark2
    mark2
  • Who's Online   6 Members, 0 Anonymous, 628 Guests (See full list)
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
