Bad u joints
I posted in here because i have 2001 tahoe 5.3 4wd, so mostly the same as silverado/sierra 1500. Im getting a lot of clunking when i shift to drive or reverse. Also im hearing loud sqeaking when i reverse or drive forward. Would this be my u joints going out? My tahoe has 185000 miles on it and as far as know the u joints havent been replaced.
Sounds like it. But won't know till you actually get down there and listen to it ro pull the shaft and check them by hand
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
