Seat cushion problem
I've read about the seat issue regarding movement but I'm not sure if this is the same.
Bought my truck used and the drivers seat is plenty worn (standard flat bolster crap). I was planning on replacing the foam to freshen it up for myself but just seems like it's not connected to the seat base.
I feel like if I pull the back of the seat cover enough, it will pull the whole thing back in place.
Sent from my XT1650 using Tapatalk
It is possible (but seems unlikely) that the seat has become unclipped from the seat frame.  If I remember from when I fixed my seat heating pad, the leather upholstery clips are what holds the foam cushion to the frame.  If the clips that run along that back line where it submerges under the seat back come undone, the seat cushion could feel loose.  I think you could check it without having to remove the whole seat.
If that's not the problem, removing the whole chair and then replacing your seat cushion foam as you were planning on would probably identify and remedy the issue.  Doing the seat bottom is pretty easy (easier than doing the seat back), my how to I did for the seat heater might help a little.
