- 0
08 Suburban LTZ no start
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 9 Members, 0 Anonymous, 1,576 Guests (See full list)
Question
Colín Edward
The vehicle has intermittent no crank / no start issues, displaying:
Service Stabilitrak
Service 4 Wheel Drive
Service ABS
Service Traction Control
Service Suspension
Park Assist Off
Most times it will go away if I poke around under the dash with my left foot.
I’ve replaced the positive and negative battery cables, with mega fuse, and had my battery and alternator tested.
The other day, I also noticed that it started shifting hard going from 1st to 2nd. It may or may not be unrelated.
i’ve attached a OBDII scan log. The HVAC code was because I had disconnected the A/C control module while installing a new radio.
Thanks in advance for your help!
Scan-Jun_03_2018_11-54-12-AM.pdf
update: I opened up the BCM and the solder joints look great. The conformal coating is still in tact. There were 2 large 220 uF caps that looked good. No internal relays to speak of. In previous generations, the relay solder joints seemed to be the weak points. Next I need to look st the PCM and TCM.
Edited by Colín EdwardLink to comment
17 answers to this question
