2017 Silverado 1500 Plow Upgrades?
Hello all!
 I live up in Central New York (unfortunately) and 6 months out of the year it snows, also unfortunate. ANYWAYS, im putting a plow on my 1500 and I was wondering if there are any suspension upgrades that I need such as, upgraded struts, shocks, ect. The truck already has a 3.5" lift/level from rough country in it. The kit only provides rear shocks, which im not sure give the truck any more strength rather than ride quality... Any info will help as im trying to be proactive before the snow flies
