moaning/resonating noise
Hi, new to forum here.  I've read over several threads here and seen an lot of similarities but I am not sure what I am hearing.  I bought a certified used 2015 Silverado LT 6 weeks ago.  I am noticing on a smooth road
with radio off about 30 mph I hear a moan/resonating noise, steady and nothing changes until I hit 59 mph it gets louder through 63 mph then kinda goes away, it may be still doing it I just can't hear it wind noise traffic etc.
This still happens weather I have it in 2H or auto.  I've even dropped it in neutral at 59 and noise is same.  Doesn't matter if I'm on the throttle or coasting.  I also have a that "clunk" noise sometimes that others mentioned here
when shifting from reverse to forward and on a slow deceleration when downshift occurs.  I haven't taken it back to the dealer yet, I would like to somehow pin it down first to what is actually happening before I do.  Is it a transmission issue, differential (front or rear or both) driveshaft, yoke or what?  Thanks.
Probably just the tires. Closely inspect your tires visually for cupping. Run your hand across the tires outside edges and if you feel any cupped areas go buy a nice set of michelins and BAM problem solved..............
Well, the tires are brand new, I had the dealer put on tires as part of the deal.  They are Goodyear Wranglers SR-A's.  I will check for cupping tho.
I had SR-As on my Titan. Those things were HORRIBLE. They wore really irregularly and didn't last all that long.
I had them on my Nissan Frontier I had.  I didn't have any problems with them. DNT posted to check for cupping which I did.  I don't feel anything but I am not real sure what cupping would feel like.  I only checked the front as that seems to be where the noise is coming from.  However I did notice yesterday driving home on a straight stretch of road I could turn the wheel to the left briefly and the noise would quiet down almost completely.
You have a bad front wheel bearing. If the noise goes away turning left than theleft is bad. You will probably notice if you turn slightly to the right it will be louder
Have an appointment with service dept on Tuesday.  He said from what I described he thinks wheel bearing, also I mentioned to him I also feel a slight vibration in steering wheel.
Lots of people hate the Goodyear SR-A however I have a set I just retired that were very worn and fairly cupped and they still provided the smoothest ride with the best gas mileage I've seen on this truck. I wouldn't buy them new because I need a little better off pavment traction.
How's your alignment?
Maybe try rotating the tires and see if the noise changes.
Sent from my SM-N950U using Tapatalk
*FIXED*  Both front wheel bearings replaced.  Service Manager told me they weren't worn but had rough spots on them.  All quiet now !
    BrandonFranceschi
    BrandonFranceschi
  • Who's Online   4 Members, 1 Anonymous, 1,267 Guests (See full list)
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
