Chilton manual?
Back in the day, I’d always get a Chilton manual for the vehicle I was working on. I have one for my motorcycle, truck is still under warranty, but I’m thinking ahead. It’s a 17 1500. Do most people just do online search or go by what they read on the forums?
I used to used them extensively. Now with you tube the last do it yourself project I did ( inside door handle on a 98 two door Tahoe) it made the job easy. It was totally different than I would have tried.
Google, You tube and Chiltons are good.
For the best information GM service manuals are the best.
Expensive, yes.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 812 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
