https://www.safercar.gov/staticfiles/safercar/pdf/EA11-001_closing_rpt.pdf
I found this picture by accident after three hours of searching for a picture of the routing for the steel lines for my  2006 GMC Sierra 4wd.  Most other GM trucks would be the same or very similar.
I cannot find a way to post just the picture.  Open the link in Adobe Acrobat and go to page 14.  You can blow up the picture in Acrobat, around 300 % gives you a clear easy to read picture.
lines run in order, from inside edge of frame (in plasic clips) or top edge of frame (in plastic clips) outward or downward.   If you run your lines in this order there is no crossing or bending of lines necessary.
Antilock brake ports:
1. top center port to right front brake
2. top left port to left front brake
3. top right port to rear brakes (actually, this line runs in it's own clip
4. bottom left port to master cylinder rear port
5. bottom right port to master cylinder front port
Thank you Joisey for posting this. I had the brake line rust through going to the right front last week. 99 Silverado 2500 (no HD), that I had bought in 2010. While replacing the line I noticed 3 other brake lines had already been replaced, which kind of surprised me a bit, seeing very little other rust under there.
It wasn't a fun job for sure, doing it on a creeper, with no lift. It was equipped with standard 1/4 inch tubing, but of course the flare nuts GM used are different from the flare nuts that come on the tubing that you find at the auto parts store. They did have the correct flare nuts in stock, I just had to cut the tubing to install them and re-flare them again. I had a double lip flaring tool.  I came straight out of the ABS controller with the new line  and ran it along the inside of the frame, ( it came from the factory coming out of the controller and going to the outside of the frame rail) and then pretty much routed it the rest of the way as it was from the factory.
I tried gravity bleeding the system first. When that didn't work, my wife helped me bleed them and now all is well.
I know I might have found the lines at the dealer with the correct flare nuts but I've found your usually better off in the long run not going there until your forced to.
I'm glad that the diagram helped you.  I used the FineLines replacement lines the first time.  My original lines lasted 84K and I replaced them when they began to weep.  The FineLines lasted 36K and rusted thru.  My current set is made by Dorman and is stainless steel.  Fit is excellent, but I will never know how they last because the truck is going down the road.  Enough is enough.
Again, I am happy that the diagram helped you.
     I usually just leave the old lines in place, and run the new lines along side them. You can spray the new lines with rust inhibitor once per year to keep them from rusting out.
      To post the picture, try this:
      Get the image on your screen, and then hold down "Control" and press "print screen" - which is located to the right of F12. Then open Microsoft paint, and select "Paste". Now just save the file to the desktop, and upload to the site.
I undercoated the first set of FineLine "lifetime" brake lines when I was sure there were no leaks.  Four years later they ruptured at the weld line.  One front driver's side and the main line feeding the rear brakes.  GM said there is no trouble with their brake lines, but on new trucks they are plastic coated, just like the two lines going to my rear wheel cylinders  on my 2006 Sierra.
I would have tried the 'print screen' idea, but alas, I have no MS paint.
   Assuming that you have a smart phone, you could screenshot it and upload that way. Or take a picture of your desktop computer using the phone, and upload.
      If you right click on this image, you should be able to save it to your desktop. Then you should be able to upload it to the server.
Edited by starman8tdc
Does anyone know the connector (nut) size that connects the brake line (right front) to the ABS module? 99 silverado 4wd
Edited by Jfayadjr
I replaced almost all my lines with nylon-coated pre-bent steel lines from GM.  Still look good after 4 years and about 50k miles.  Only dumb thing about them is that GM didn't include the 2 lines going across the rear axle and they don't sell those lines separately anymore either...
It's a 5/16 to 1/4 reducer,brass,all parts stores have them,this way a 1/4 " line can be used with out touching the flare
  • 8 months later...
I have a 2006 GMC Sierra 4 x 4 Crew cab SLE. My lines are the tc04 727. They DO NOT go into the ports like everything I've seen says. The only diagram I gave found is from dealership or nemigaparts. It does not clearly show proper routing/port locations. I'm at my wits end here.spacer.png
I know from the only color code left my Rear Master cylinder line goes into the Top Middle port. I also know the line running to the rear (drums by the way) goes into the Top Right port. I am also fairly confident the Left front (Driver's side) line goes into the Top Left port. Other than that....HEEELLLLPPP!
Edited by ChrisMatthews
Addional info
That would be your best bet.  When I did my lines years ago, I made sure to take pics of line routing (particularly along the frame rail from the front wheel to the abs controller, but also if it goes over/under various bits).
And be careful with the various clips holding the lines in place, as at least some of them are NLA new, and are very difficult to remove from another truck (say, in a junkyard) without also breaking them.
Thanks Dave. Clips were pita, but patience and determination won in those. I took pictures, lots of them, trouble is the lines twist over the frame by the firewall. Also the pictures I took help quite a bit, however it only takes 1 out of the bunch to mess you up. I planned on paying close attention near the ebcm, but the lines snapped like dead branches. Looked at several trucks, all a bit different. I did gain perspective on the lines going through the clips though. Haven't yet determined if that helps me or not yet.
    • Yes they are a good addition to make the truck more visible.   I have the OE ones in the lower front corners. I added some amber fogs to the bumper from Diode Dynamics SS6 model and wired them to my upfitter switches.
    • I had an issue with a new 1985 Z-28 some years ago. The 4WDB's were less than adequate when purchased IMO.  I had taken it in for small warranty services and asked them on three occasions to check them. Each time is was "could not duplicate on the service ticket. The warranty ran out about a month after my last visit and had to take it back for warranty rework. I again complained about the brakes. Well, low and behold, this time they determined the rear calipers were sticking and gave me a quote to repair. They had records as well as O had receipts of each time complained about the brakes while still under warranty. My dad was a life long body shop owner and told me to keep my cool and tell them that I wanted to speak to the GM Regional District Manager. The service manager disappeared for a few minutes, came back and told me they would replace the calipers free of charge.
    • Towing a 2022 Lance 24 ft travel trailer with our 2021 GMC Sierra 2500HD, gas.  Loaded, trailer is about 6,000 lb.  We get up to 10 mpg at 55 mpg, such as I-5.  Pleased with the combination.
    • I decided to give it a shot and see what sort of a gong show it would be to a pan drop themed oil change on my 2025 gas truck with the 10 speed. All indications I had seen so far was that there was no way that pan was coming out of there due to the cross over exhaust pipe not allowing enough clearance for the back end of the pan to duck out from under the valve body since it hangs lower than the pan to trans mount flange and certainly the filter does. I never touched any of the exhaust mount hardware at all, be that the engine manifolds to Y pipe, the bracket on the side of the transmission, or the two bolt flange further back behind the trans/transfer case. I put the truck up on four jack stands as there was no way I was going to struggle with that lack of clearance under the truck. The truck was cold as it had sat over night so all the trans fluid had drained to the pan, so I drained the bit of oil that would come out of the level check plug at the bottom near the front of the pan and put the plug back in to reduce the ensuing mess after that. Then took out all but one bolt front and rear and then pushed up on the pan and took out the remaining two bolts and then let the front of the pan tilt and spill out most of its contents into a drain pan. I then popped the pan gasket off its two locating nubs and kicked it a bit to the left side so it was no longer on the flange of the pan to get all the clearance I could and managed to get the pan slipped out of there by swinging the front of the pan to the right but keeping the rear part of the pan inline if not slightly to the left of its mounting flange area and lifting the front of the pan enough to keep the rear part of the pan low enough that allowed the pan to "JUST" slip out without forcing anything. I installed a new trans filter and seal and as per GM instructions on this site I torqued the two bolts to that 44 inch pound goal ( they take an 8 mm socket ) In reversing the pan procedure after I had cleaned up the pan both inside and out completely ( touching the outside of a dirty pan and dealing with installing a gasket at the same time would be a disaster ). First I slipped the pan into place and yes it took me a while as it won't go unless its slid in just at the right angles, then once the back of the pan was into the area of the flange mount, I went and got the gasket and then threaded that through the front of the pan and feeding it under the filter etc and finally working it onto the flange of the pan and lining up the two locating nubs to drop into the pan. Then lifted the pan up into place and get a couple of bolts started and check and make sure the gasket is where its supposed to be as the bolts were being put in. I never used any power tools as I don't have any of the whimsy little drive guns, I use what looks like a small screw driver handle with shank that has a 1/4 drive on the end of it and added an extension and those bolts use a 10 mm socket as some times power tools can bite a person if used on delicate parts ( torqued to 80 inch pounds ). Also should note as per rules around pulling the add plug out first, yes I cracked that loose with a 8 mm Allen bit socket on a 3/8 slim head ratchet as there isn't a lot of room to work with there either due to the exhaust on the right side of the trans.    I already had delco ULV oil on hand and of course the quart bottle pump wasn't made for those small cap threads so I had to use some other containers that the pump would fit and keep transferring oil over into them so a wasted exercise there but indeed the small pump did work just fine as ULV oil is thin and easy to pump in summer time weather. I put in 9.5 quarts as per prior minimum recommendation and yes that cut it pretty close as once I had the truck ( off the jack stands so its level ) and the trans oil up to 167f , about 6 ounces came out but a level kit or what have you could throw it off just enough that it wouldn't be enough oil so probably that 10 quarts is a good amount to put in so one doesn't have to add more oil as when its hot I sure wouldn't want to be adding oil so would have to let the exhaust cool. All I do for warming up the transmission is sit there with it in park and rev it to about 2500 rpm and it takes close to 20 minutes to get it up to that lower limit of 167f, weird how it will warm up more doing that then by driving it, I am not real keen on power braking the truck to get the temp up there and don't seem to have to either. By the way I only have 9000 miles on the truck so probably not a very good payback on doing it that soon and the magnets had such a minor thin layer of fines on them so that was good to see and the color of the oil was a darker red then new oil but still looked very good as it should and I've not done any towing with it so its been living a pretty easy life so far. The filter is made in such a way that its next to impossible to pull out the filter media but there certainly was some fines showing up there which makes sense give the trans having to break in.    I hadn't really planned on explaining this much of what I had done since there are various instruction videos kicking around or I think so, as the gist of my message as that by fluke or what have you, for some reason my truck has just enough clearance to slip the pan out from the trans. Of course there is no guarantee that other trucks like this in general will also allow the pan to be taken out without messing with the exhaust as I expect its probably a crap shoot if it will or won't, I was just happy to find out that mine would work and avoid all the other struggling and possibly damaging things in the process,
    • Do you fellas think Fog Lamps would  be a good upgrade for our 2024 2500 HD Custom ? As you probably know it did not come with them ,  Would you put in GM Chevy parts ? Do they get wired up to the switch panel ( Upfitter or whatever the correct terminology is ) on the dash ? Thanks
