Aftermarket support?
What are some companies that provide aftermarket parts like level kits, exterior parts like bumpers or skid plates? For a 2017 z71 1500 I only have done window tint seat covers and all wheather floor mats so far.
I have heard of
Mazzulla, SDHQ, Move bumpers, CST, and rough country.
Any others I should know about
*-EDIT-*
Also interested in a catch can but know nothing about them or where to buy them or how to hook it up. Only have a general idea of how it works.
Check out websites like realtruck.com, autoanything.com, carid.com and americantrucks.com. They have a ton of aftermarket options available. If you're looking for specific feedback on brands you should be more specific on what parts you're looking to upgrade and read some of the posts here on those topics (eg. lifts, caps/tonneau covers, nerf bars, etc.)
Right, I have checked out a few of those sites. I wont order any thing from carid after my last encounter with them.
I'm just really looking for something to do to the truck with out spending $1000 bucks here and there.
Thanks for the feed back
