Powerstop Brakes
After installing the Powerstop rotors and pads I have a high speed vibration in the front and the rear of my truck.
Had anyone had a problem and checked the run out on their powerstop rotors?
I'm wondering if mine are out of spec...
2 hours ago, Aboogie808 said:
That isn’t normal. Who installed it?
My friend and I.
We have done a lot of brakes jobs on many different types of vehicles.
1 hour ago, CMoore711 said:
Did you bed-in your new brake pads properly?
Yes
I did perform 3-4 stops from 45mph
 and 7 stops from 60mph down to 15mph
then cruised down the road
1 hour ago, Toolbox1 said:
High speed vibration when braking? Or just when driving?
Just when driving at 63 and up.
I had a vibration  when braking with factory rotors. This is why I replaced them.
I had a Jeep wrangler that vibrated in steering wheel after installing a big brake kit on it.
Come to find out the rotor was 11 thousandths out on the run out.  Only felt it at 60 MPH and up.
