Where do you get a good bike rack?
lyonsd
Not sure about a rack as per your request, but I used a swing away 4 bike rack from OSI on my Suburban, and now on my Avalanche.  It works great, really well built, and saves lifting the bikes onto the roof, and knocking them off on gas station awnings, low bridges and carports.
Here is a website with them...
http://www.accessconnect.com/bike.htm
It is 4th item down, the Swing Away rack.  Don't know if this helps at all, hope it does.
Good Luck
Scott
I'm heading out to the beach tomorrow and was hoping to find a bike rack at Wal-Mart.  I didn't like what they had.
Is it safe to use rope and/or bungee cords to attach bikes to the racks on the roof?
The only bike accessory I'd buy at Wally Land is tubes, otherwise stick to a local bike shop or online.  By way of racks, Yakima is king of the aftermarket rack world.  They have quite a variety, depending on your wants and needs.  If you're in a hurry, I know our local Dick's Sporting Goods carries them, or again, check your local bike shop.  If you've got at least a little time, check them out on-line.
Wowsers...someone else is looking for a bike rack!  me too!  Here are a few sites to get you started:
www.performancebike.com
www.nashbar.com
www.coloradocyclist.com
www.yakima.com
www.sarisproducts.com
www.thuleracks.com
How tall are you?  You need a good reach or a step of some sort to get the bikes up on a roof mount...easily and without scratching your truck.  Another thing to consider with this style are low hanging trees, parking garages, your own garage.  I have a friend that did ~$1000 damage to his garage, garage door, and truck roof when he forgot he had bikes on top.  No damage (maybe a scratch or two) to his bikes though, they came off with the rack.  :D  He now has an "idiot tag" hanging on his mirror to help remind him. :D
I have a Tahoe and I've limited myself to a hitch mounted bike rack (swing out style).  That way I can just swing out the bikes and load larger stuff into my Tahoe.  You don't have to go around like you would with the tilt down version.  Only problems I can think of with this style is:
1)  probably more expensive ($159-$350 for hitch, $80-$200 for roof)
2)  might block your vision a little out the back
3)  adds a little length to your vehicle
btw Don't just tie your bikes to the roof.  Way too easy to scratch your truck!
I forgot to mention, it's best to go to a professional bike store.  The sales people there probably have something on their own vehicle and can offer "user" insight.  Sometimes (with the right dealer) they provide a discount if its a new style/brand or whatever.  Mine did that for me since he hadn't seen one mounted on a minivan 10years ago.  I just reported how it worked...what I liked and disliked with it.
I used to work at a bike shop and I have always owned SUVs, so I will share my .02. I would go the hitch route because SUVs are tall and has already been stated damage can be done by having bikes on the roof. There are a variety of manufacturers that make quality hitch mounted racks. The main difference between them is how they actually hold the bikes; some use the frame, some hold the wheels, some use the fork. You will just need to find one that meets your needs.
If you decide to go with a roof mounted unit I would use either Thule or Yakima, both make great stuff. A roof rack from either of these two companies is usually more expensive than the hitch mounted rack. The main benefit of a roof rack is it can be used for bikes; skis; canoe; kayak; and gear box. Most hitch mounted racks are not multi-purpose.
Let me know if I can help you in anyway.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
