2019 Colorado Z71
Is anyone else spec'ing out a 2019 Colorado. I am getting conflicting information.
I am buying a 2019 Colorado Z71 2WD (the only model now that you can get NAV) and plan on getting a V6.
The dealer's build program indicates that the base price is for the 4 cylinder and upgrading to a V6 is an extra $1165 (Cdn). It appears online, that the 4 cylinder isn't an available option on the Z71, so the base price should be the V6.
I am hoping that someone has information that would confirm that GM is phasing out the 4 cylinder on the higher level crewcabs
Thanks
Make sure you spend a lot of time behind the wheel of one before you buy, I had a 2017 and traded it in after two months for a SIlverado cause I couldn't stand the truck.
  • 3 weeks later...
The base price plus the V6 upgrade is the base price for v6 equipped trucks. If you want a base truck, you're gonna get an inline 4. If you want the V6 you're gonna have to pay for it. I think you can get the Inline 4 in any trim except the ZR2. But they are very rare unless specifically ordered that way.
Not sure exactly what you are asking. But, I would save your money on the NAV option. The factory NAV is junk. Plus with Apple Carplay and Android Auto coming on these, you can "stream" navigation from your phone to the screen on the truck. Google Maps and Apple maps are light years ahead of the GM factory NAV.
  • 9 months later...
I agree with fondupot on the GM Navigation system, compared to Apple it's clunky, a waste of time and money, and chip updates are expensive at $165.00 (US) per chip (or more). Yes, it seems GM is making some changes in model configuration options that are not yet reflected in the "Build and Price" systems (such as a 4 cylinder is now only available with a 6-speed automatic transmission, no more manual trans). And yes, the Z71 package is now only available with a V6 or Diesel (US -or- Canada), regardless of what you see in "Build and Price".
If you're trying to use the "Build" system, pick what you want, print it out, then go to one or more dealers and talk to a sales manager (not some salesman). The manager can model your build list in the actual order system, and at that time, then the manager could tell you what you can really get at that instant.
  • 4 weeks later...
I second that, I have a 2019, a week old, the GPS, Phone, all of it sucks...I hook up my phone to it, and use waze.  The gall of them charging anything for any type of upgrade is appalling..The whole system
is crap...
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 246 Guests (See full list)
